It's a great choice for single handing and for 2 or even 3 on board. I weight the same as you and find it the perfect size. With my previous N5.0, having a crew of my size had a noticeable impact, my N5.5 still goes fast and you can fly a hull on moderate wind. And single handing isn't much different, probably because it's a bit wider: 8' 6" vs 8' (note that 5.7 and 5.8 are also 8'). I sail sometimes solo and most often with my two daughters and wife, usually two of them with me, sometimes all four of us. (They are light, four adults of your size would be too much, three would be in the edge).
Here is one them with me.
https://www.youtube.com/watch?v=24R_BmTW64U
You may find that the bows are a bit too submerged at some points, this is because the crew should be further aft, but my daughter feels safer with her feet touching the front beam and the stay (she needs some decent sailing boots)
For a recreational sailor that I am, I also find a good compromise between simplicity and tuning possibilities.
If your jib blocks are attached to the hulls it won't point well, either get the 4-way jib system, which I find a bit too complicated, or just have a decent line attached from one side to the other, with a couple loops to attach the jib blocks. Somewhere close to the hiking straps is fine. I made an adjustable system but I rarely adjust it.
You will enjoy the boat. Good luck!
