Posted: Apr 16, 2015 - 09:09 PM
OK, Dogboy has the intel on the Hobie.
One other thing many do,(maybe not applicable to the Hobie if it doesn't run under tramp) is to attach a small block to the rear beam, & run extra bungee from one side back to this blkock, then forward to the other side.
This allows lots of stretch, & if you go Peter Panning, or elsewhere during a flip, there is enough play in the system that you don't break the bungee.
Hopefully someone has a decent photo of your setup.
