Turnbuckle with a roller furling
My Prindle 18-2 has a roller furling and it is attached to the forestay with a turnbuckle. I just can't get the negative thoughts out of my head regarding the turnbuckle unthreading one day while the furler is spinning. Am I over thinking this or is a turnbuckle just a bad idea here? Thanks Pete
New Prindle 18-2 Owner
Former Prindle 18 Owner
Multiple Hobie 16s
Boylston Massachusetts
not good....get a 1/4 inch shackle and be done with the worrying....not even sure the three stooges would use a turnbuckle....just my $.02
Mike Conway
Hilton, NY
No problem at all, just make sure the counter-nuts ( translation ? )
which keep the threaded ends on the turnbuckle in place are tight
and taped with volcanic tape.
Still not able to sleep ? Replace it with something like this.
http://www.murrays.com/mm5/graphics/00000001/50-60830000.jpg
Grtz, André
Tornado (80's Reg White)
Prindle 18-2 (sold)
Dart 16 (hired and hooked)
13 mtr steel cutter (sold)
Amsterdam, the Netherlands
Or use cable ties
Thanks guys.
Multiple Hobie 16s
Or Loctite.
I believe this is stock for the 18-2 and should not be a problem.
http://www.murrays.com/mm5/graphics/00000001/Forestay_Prindle.jpg
http://www.murrays.com/02-2545-42.html
since you would have to cut off the turnbuckle. you would probably need to replace the entire forestay to change to another system (chainplate or thimbled end) - not a big deal but some Loctite and rigging tape would be cheaper
Edited by MN3 on Apr 20, 2015 - 07:43 AM.
MN3I believe this is stock for the 18-2 and should not be a problem.
HaHa there you go then, never would have guessed what he described was the factory setup.
