Ed nailed it. His beam extender made the line easier to hold, but could not change the righting moment so long as his weight was in the same place. You'd get the same moment with the righting line tied down closer to your feet, but at some point, it would be impossible to hang on. To increase the moment, you'd have to get your body out further from the lower hull (without it going into the water and neutralizing your weight) ....like with Hobie Gary's Solo~Right or some such pole system.
If I sailed in Canada, I probably wouldn't waste a second of the season waxing either!
Dimpled hulls.....hmmmmmm.......they'd probably just make an H16 pitchpole easier!
Clinton, Mississippi
