But Boy was I having fun! HA
Guys: Thanks for all the help thus far.
Conditions:
Air Temp 96, Wind during first session 14, and Wind during second session: 17 w/ gusts to 22. High pressure all day with wind shifting direction 100 degrees in about 1 hour time—the whole time we were on the water during second sail.
I got to the boat launch at 9 and my helper and I got in the boat in the water at 11. We sailed around for an hour, came in and had lunch.
We got back in the water at a few minutes past noon and sailed around for a while. Although water had only 1’ waves near shore out further in the Chesapeake just north of the tallest span of the Chesapeake Bay Bridge, waves were 3’ with slight white caps. No problems aside from the fact the jib sheet was slightly frayed after being dragged via towing the boat and the sheath was coming undone, blocks were adding to the line coming apart. I tried various sail trims going different directions to determine optimal sail trims. We headed north towards the Magothy River about ½ mile from shore and I noticed the wind picking up, and gusting. The wind shifted from SE to NW pretty fast and as we approached the Magothy wind was ripping pretty good straight down the river out into the Bay. I was playing the gusts very good turning upwind upon noticing dark water coming at us. We were doing well, then without warning, we went over. My first scary thought was that mast was going to sink as I had forgotten to tie the small light weight plastic inner tube to the top of the mast (insurance) as I had done in the past. I did however seal the mast so now was the test to see if mast floated. We got up on the bottom hull and I deployed the righting line that was fashioned in a loop with blocks underneath the tramp. We tugged and the boat flipped up. And then, flipped over again. The boat tramp was facing the wind with the sail leeward. Now comes the fun part:
We had difficulty getting the boat back up. In one instance both hulls shot straight up as we were too far back on the hull. My crew was getting burned out and I realized I had one last chance to get the boat up before calling for help. Being blown out into the middle of the Chesapeake, we were forced to do a ballet dance on the hull (teeter totter) to get the right balance to swing the boat into the wind. Finally, with a lot of finesse with foot movement the boat turned and we were able to pull up the boat. This time I made sure to grab the lower hull to keep it from going over again as I knew this was our only chance. (I didn’t even consider using my righting pole…) After about 30 minutes from capsize we got the boat up. Once up and on the tramp, I assessed our situation: We lost all our drinking water, mate lost $200 sunglasses, I lost my ball cap, boom cap came off and was hanging down, pin still there, ( I suppose that happened when we both slide down the tramp onto the sail etc.)
While I held the tiller I asked my mate to tie the boom to the mast. This is when I realized he so lacked any mechanical ability and was not much help. He knew not one term and seemed to forget terms. I was teaching a little during first session with him only dealing with the jib sheet-- one line. I ended up getting the mast tied up and just so happened we were now heading south back towards the bridge and towards our landing spot. By this time we were tired, dehydrated etc. Mate was glad to be back on the boat but his first statement... we need to head back in! Apprehensive. I was enjoying the day! And knew we had at least one tack to put us on final course for beach.
The water cooled me a tad. We got up to near where our landing spot was and I needed to tack—after about 8 or 9 attempts the boat wouldn’t tack. This was due mostly to the fact that the jib sheet had come apart and was getting hung up in the block. Sensing we were in danger, my mate said: we better call the Coast Guard. He started to wave at a boat nearly 3 miles away. I told him we were OK etc. to calm him. I decided to get the CG on the radio, to cure his fears a tad, plus at least alert them that we might be having problems etc. The bridge, waves and being the only ones out there except for freighters and coal barges, with the threat of capsizing again probably added to his apprehension. It took 5 minutes or so then I heard CG asking other boats to come to our aid? By this time we were 200 yards downwind from the Bay Bridge. I didn’t want to get underneath the bridge, yet couldn’t tack. Waves were now 3-4’ wind was gusting. Jib was not helping, not being able to trim it correctly. So I made the decision to bear off away from the wind to change direction. (I did this as I didn’t want to be upwind from the bridge in the event of capsizing.) The sail swung around and nearly knocked my mate off the boat! Now were heading directly for the beach where the put in was. My mate was now relieved that he could see we were heading in.
This leg was pretty enjoyable for me as we were just sailing… sun was out, yet I was pretty thirsty. When we got 40 yards off shore from the take-out the wind put us in irons, between to rock jetties 50 ft. apart. I attempted to tack but had problems… I said, well the only thing we haven’t done yet was PADDLE THE BOAT! He immediately grabbed the paddle and took some strokes then when were within swimming distance he jumped into the water and towed the boat to shore via swimming! Boy he was so anxious to get his feet on the ground! It took another persons’ help to push the boat out of the water as both my mate and I were pretty exhausted.
I looked down and for the first time notice my small toe—cocked out 90 degrees, a definite break as later revealed via x-ray. Weird there was little pain…that I didn’t notice. Perhaps I was hurting more elsewhere for knocks and bruises. We were out of the water at 3 pm. Fortunately the wind was directly in line with the ramp making getting the sail unhooked without moving the boat. A real treat.
Overall I pretty much accomplished everything I wanted to do with this boat except trying to right the boat myself, which I’ve decided will not happen. It's fun to sail, but there's just waaaay too much work for as little please IMHO.
Here’s what I might have done:
1. Make sure all personal items are Totally secured.
2. Never sail with frayed sheeting lines, especially ones that go through ratcheting blocks or cleats etc.
3. Know your mate. (I met this person at the beach and he sailed with me during second splash, seemed OK. I really needed him for his weight in righting the boat. Without him, I think it would have been impossible for me to right the boat by myself, even with the righting pole I made.)
4. Don’t rely on CG. Here, they summoned other boaters to help us? Besides, I can’t think of how another boat could have helped as if towed while the sail was up may have caused us to capsize? I did make the call that we were OK and were heading back in. Life Guard in ATV came up to us and asked us what the heck we were doing out there, smiling. I said: just having fun!
5. Wear booties to protect toes and help grip standing on hull in the event of capsize. Hull was like standing on ice.
6. Have someone with you to help right the boat, especially when you are in open bay or ocean.
7. I didn’t have on a long sleeve shirt and my arms got fried. Boy it was a hot dry day. Losing the hat cost more sunburn on my face especially since I forgot to use sunblock… which I usually never forget.
We got everything packed up and met at 7-11 for beverages, slurping on water, slurpies I told my mate that we were totally experienced now: capsizing, breaking boat, hobbling back in, getting hurt etc. I asked: Would you go again. He said: “Any time, I’m down here several days a week just let me know.” Not sure if he was telling the truth. I probably won’t ever find out as I’m done sailing this boat, I think.
Hobie 18
Two person boat, possible two cat trax wheels for ground handling, no so effective rudders, nice boat for putting up Friday night, sailing Sat and Sun with take down Sun night. Labor intensive for one person, to put up and take down and sail in one day especially if injured and tired from capsizing. Good boat for mast up storage on beach. A forgiving boat at wind @ 15 and unpredictable as far as capsize @ 17+ with gusts in 20’s. Tracks pretty good. Not as wet as I thought it would be. Takes up lots of room in driveway.
Thanks for all the help guys. Hope you enjoyed following along. I’m selling the boat as I think I’m going to try a WAVE, once this one is gone and when my toe heals—4 weeks or so. I’ll post a classified soon or just PM me if you want to buy this one. Its battle tested! New boom end cap is on the way. OH by the way: mast floated, and hulls had no water in them. Pretty amazing since it was on its side for a while. It’s a real sturdy boat. Gelcoat is still shinny on interior hulls.
If you have any tips, please leave them. It's all about team work and I'm glad thebeachcat team has helped. Much appreciated. Believe me. You made it much easier.
Thanks again.
Goodsailing!
Goodsailing
H18 (Sold 7/15)
Balt-Wash Area
