New to spreaders and diamond wires, I have been cautioned to make certain that the diamond wires are securely safety wired to the spreader as inadvertent detachment can result in mast failure. The safety wire currently installed must be replaced as it has failed (note that the boat is new to me and I'm in the process of getting it on its feet, this is the as delivered condition).
Does anyone have a diagram of the proper OEM safety wire installation technique, routing, twisting configuration? I've looked at the manual to see only the two link spreaders shown with very fuzzy photos and and sketchy written instructions which lack detail.
Lastly, the safety wire that came with the boat measures 0.029". I'm planning to use 0.032" as it's the closest "standard" size I find. Is that the correct diameter?
Thanks In Advance
Edited by leeboweffect on Jul 26, 2015 - 02:06 PM.
