89 SEAWIND 24X16 FOR SALE NEWPORT BEACH CALIFORNIA
Modifed Seawind Cat with Klegacell Hard Deck and marine ply/west expoxy Cabin.
Four single berths, Main cabin for two more. Total of 6.
Evinrude 6 horse with charging alternator.
Propane 2 Burner Stove, 12 volt Fridge,Kenwood Stereo/Bose 5150 Speakers and Solar charging.
Sail Inventory: Three jibs(two are North Sails), spinnaker, main.
Kickup Rudders.
Additional two mast spreaders added.
Carbon sprit pole
Salt Water pump for SInk in the Galley.
Electric non macerate pump for the head which is mounted on starboard side.
Can use the anchor lockers for fresh water tanks.
Removed the center pod that the engine was mounted in. Removed the lower portion of it and installed it at the rear for mounting the engine. This achieved two goals. Provided mounting for the engine using the original outboard mount of which the lower section still has the taper for cutting through the water, and reduces the weight by a huge factor that offsets the weight gain of the deck and cabin. Just a win all day long.
Done over 20+ knots of speed, even passed the Alcatraz Ferry twice!
dropbox.com/sc/w5yaku35a363i47/AAB-GHdIXyYKfu-TS5e8LNZJa
$7500
Allen
949.482.7785
renospec@gmail.com
Edited by renospec on Jul 30, 2015 - 07:17 PM.
