Decided it was time to remove the old tramp and replace it with a new Slo version. Removed the front crossbar's two nuts per side with no issues whatsoever. When the crossbar came off, the cradles on both hulls were full of dirt? Cleaned up the cradles and everything looks good:
There appears to be no bedding material (silicone, silicone/polyurethane blend, caulk etc.) between the crossbar and the cradle. My experience with assemblies of this type is that there should be to stabilize the assembly and prevent working between the components. Comments?
A crazy thing I discovered while doing the tramp is that type of rivets used to attach the tramp rail on the port and starboard hulls is different. The starboard hull tramp rail is attached with aluminum rivets while the port hull tramp rail is attached with stainless steel (SS) rivets. Which type of rivets are OEM? Obviously, the SS rivets pull much harder than the aluminum rivets and are much stronger. I realized that a previous owner along the way may have re-installed one or both of the rails and inadvertently used a non OEM type of rivet. I was surprised that none of the rivets were installed with backing washers. Are washers OEM? Comments?
I noticed that the aluminum rivets on the starboard hull tramp rail were raised a bit. Is that common? Some of the Tramp rail rivets appear to have been installed without any type of sealant. I'm very concerned about leaks. Comments?
While poking around inside the hull, I couldn't help but notice how sloppy the lay up was. Truly a lot of dry cloth in places with excess resin (additional weight with no structural benefit) running in others.
