hello all, newbie to mulithulls here...
Last week I snapped a crossmember bolt on my Prindle 16. Most likely they are original 1982, so I am changing them out.
I noticed that the rudders and hulls "fan out" a bit, wider at the bottom than at the waterline. All of the other (newer) cats I am looking at have very parallel hulls and rudders. Any reason I should not make them parallel on this Prindle? There is a lot of forum chatter about parallel rudders, but that is only in the forward to aft dimension, adjustable on the rudder connecting arm. I am referring to the rudders and keel just getting farther apart as they go down, and it appears the Prindle is designed to do that. Hope that is clear and look forward to any comments. Thanks,
Paul
Prindle 16
"Nuissa"
