OK, the standard setup is as Cook shows above.(click on his last photo to expand it).
Do you have both Nacra manuals?
If not, download them from this site.
Unlike the Hobie, your jib should NEVER be taking the rigging strain. You will attach your forestay & shrouds, then tension the rig. Many do it by hanging in a harness & having a buddy re-pin a shroud.
The factory rig for the jib consists of a halyard that is part line, & part wire rope,(note Cooks photo shows a block for cable vs regular line).
Your jib halyard will run up the mast, with the wire portion running through the wire block that is shackled to the mast at the hound(obviously this must be done before raising mast), then back down.
Unzip the long zipper on jib. Attach the shackle on end of halyard to the loop at head of jib. Now, put the jib on the forestay, & raise the jib, doing up the zipper as it raises.
When done the jib will be attached to the forestay.(Item #55 in one manual, Step #27 in the other explains this).
Since you trailer & setup, you will probable use the jib tack hangar. the hangar stays on rigging, you just slide the grommet in jib tack into slot & pin it.(photo 38 in older manual) If you are missing this part, PM, I have a couple.
The jib is tensioned,(see photo 60, or item #29).
I think the 5.2 used the same 3:1 system as the 5.7., looks like this;
Note wire portion going to wire block near mast hound.Note block with becket attached to the end of wire portion.
What the photo does not show clearly is;
A): the line portion of halyard,(that you will stow in tramp pocket, or remove via sister clips once jib is full hoisted)
B): That the halyard is tied to becket via a simple bowline, BUT, leave about a 20" "tail" when tying the bowline. After the jib is hoisted, this short "tail" is used to tension it.
This tail will go down from the becket, & around a cheek block on the side of the mast, back up & through the block, then down into a jam cleat on the side of the mast.
you just feed it as described,pull to whatever tension you want for the day, & cleat. You can adjust tension while sailing by simply uncleating & pulling more or less line & re-cleating.
At the end of the day, undo jib tension line, undo tack from jib hangar, & as you let the jib down, unzip it. When all the way down, undo quick shackle at the head of the jib, & attach it somewhere so it's ready for next time.
Let me know if this all makes sense. Once you do it a couple times it becomes a 1 minute job.
Edited by Edchris177 on Aug 27, 2015 - 07:32 PM.
