After the dagger board repair i am more confident dealing with epoxy and fiberglass repairs but still a noob.
So boat has some minor (i guess) damage to the starboard hull. oh and it takes on water only in the starboard hull... so maybe they are related? I was thinking i would do a quick (and ugly) fix with some epoxy to fix the damage and maybe stop the leak (i doubt it).
so here is the area i am referring to.
Not a big area, only appears to be one layer of glass effected,
The area is right under the access hatch and under the tramp. From inside the hatch you can't tell where the damage is, you can feel it with your hand, but it's really hard to see. I couldn't tell you looking at the picture exactly where it is with any certainty. So i don't think this is the source of my water ingress.
Boat has been sitting outside on the beach (in VA) under a tarp with the hatches open for about a month. I was planning to just squirt some epoxy up into the slit, then trowel in some thickened epoxy, put some rare earth magnets on either side of the crack to keep it pressed down while it cures and then epoxy a thin layer over the top to fill any imperfections and holes, sand and that would be it. wasn't worried about gel coat or making it look good, the boat is old and area is basically hidden from view. But after doing more reading i'm now worried i could cause more damage if i trap water or moisture inside the hull, and that the epoxy alone isn't going to be a good barrier to moisture? - is this a problem for a beach cat that won't stay in the water? I'm not concerned about having a beautiful boat, but i am concerned about having a solid boat that I can sail and keep up for years to come.
Finally there is a second spot that i figured i'd just slap some more epoxy over to protect the glass
So am I asking for trouble not having had my hulls totally dried out for months and months? what is worse continuing to sail it with the damage and allowing more and more moisture in, or sealing it up and risking sealing some moisture in. It will be outside for VA winter.
I'd like to avoid having to grind and replace glass if i can help it, the boat is stored at the beach and I can't keep it at my home or fit it in my garage to do the work, so i'll have to do the work either on the beach or at best on a trailer. not the best place for serious repair work.
So then my final plan is with the epoxy that i have mixed up but don't use i'll spread some around the inside edge and bottoms of my dagger board case hoping to also seal up any tiny water leaks. is there a usual suspect for a Nacra 5.8 starboard hull leak that I could be looking for? I read a post about just spreading it all around the inside of the cases. i assume that only means the bottom where the case actually contacts the board and not the main body of the case? or am i wrong there? Also won't that cause a very tight fit for the boards? mine are already very snug. if i build it up at all i'm afraid i'll have to sand it all back off to get the board to fit.
1987 Nacra 5.8
1978 Isotope (sold)
