So I had an idea, Just want to make sure i'm not totally insane in thinking this is a good idea.
my hiking straps have rotted away. tramp is still serviceable. i won't be replacing it this year, i'd like to get another season or two out of it.
So i'm planning to put #4 spur grommets in the tramp everywhere the hiking straps where originally stitched (at the reinforcements) i'll then be able to loop some line through and tie on a new hiking strap(or some line as a temporary measure while i get proper length straps made with loops at both ends).
I will use the existing grommets at the bottom of the tramp for the bottom connection, and i'll put one grommet in at the top of the tramp (for each strap) and i was thinking i will loop the cross beam with the line i connect the strap to so as to not have the old tramp and grommet taking all the strain. Then two grommets each at the two reinforced points in the middle of the tramp with a simple loop through each.
Can I do this with the tramp still on the boat? i'm planning to just use a 24" 4x4, a cinder block and some 2x6 to assist in cutting the tramp and setting the grommets (basically to give me a portable work surface to cut the holes and pound the grommets). I guess my concern is that the tramp will be under a bit of tension (i'll make sure it is loose). I won't have a lot of help, i plan to do it this weekend and i want to do it as quickly as possible so i can get to sailing and not lose most of my long weekend fiddling about with projects.
I figure i don't' have much to lose, but i don't' want to ruin my currently serviceable tramp if this is really a terrible idea. But i would like to get hiking straps as it will make it more comfortable (secure feeling) for my non sailing passengers.
Thanks for the feedback and reality check.
1987 Nacra 5.8
1978 Isotope (sold)
