Posted: Sep 13, 2015 - 03:57 PM
I own a Solcat 18, Great boat. For the minor leaking get some silicone and add a dab of Silicone to each rivet for the tramp. That is where the water is getting in. Then add a long bead of Silicone along the metal piece holding in the Tramp under and over. The other place to silicone is around the Bung Plugs. I would redo this every 2 years.
Another tip is get 2 blocks , 2 steel boat hooks and about 6 feet of line.Use the blocks to help pull down the sail Cunningham. Cleat it and take the block and tackle off. That will take out all the wrinkles in your sail at the mast. This will reduce the luff and help on Reaches tremendously. ( add ad least 1 - 2 knots!) The manual one for the boat is not strong enough.
Tacking, Use the Jib to pull you around, Keep the Jib full on until it luffs, then tack the Jib, Not prior. Once you get the hang of it, it will be much easier, although all Cats have a difficult time tacking.
Last tip. Boat is very heavy and extremely difficult to right, don't tip the boat over. If you do make sure your Center boards are attached by a bungee to clips on each side of the Jib Blocks.
Have fun and good luck with the boat.
Edited by hamish66 on Sep 13, 2015 - 04:13 PM.
