My hulls are worn from dragging the boat over sand, rock, etc and so I'm considering restoring the hulls on my solid fiberglass, pre-foam core (1985) Nacra 5.2. I've googled around to get an idea of what I'd be getting into if I start this project. I'll probably just epoxy along the bottom and gel coat, however, while I'm at it, I'm weighing the pros/cons of removing the deck plates to stiffen up the hull which tends to oil-can a bit.
(On Nacras 5.2's and probably the 5.7,5.8,6.0's, the matted surfaces on the top of each hull are actually glued on fiberglass "deck plates" which can be popped off with a knife).
So a couple questions related to this undertaking:
1. Hull bottom repair: Adding fiberglass 2 to 4" wide tape, filling/feathering, then gel coating seems like a robust way to build up the hull bottom. Has anyone been satisfied with just heavy epoxy and gel coating (it'd be easier). I take on some water during a 2 hr race, maybe a quart.
2. I assume removing the existing deck plates will damage them, is there anyone that continues to sell these?
3. I don't know how concerned to be about hull oil-canning of the hulls, thus the consideration of getting access to the inside of the hulls and adding fiberglass to stiff things up. I've had the boat for 3 years and I can push the hull in roughly 1/2" in just about every mid-span location on the boat. When out on the wire, I keep my feet on the edge of the hulls, but I'm a little concerned that one day I might put my foot thru if I miss-step. The oil-canning is definately more pronounced than other Nacras I've seen, but they've all been Nacra 5.7 or 5.8's that are probably post '85 and foam-core construction.
Pairajacks
1985 Nacra 5.2
Corvallis Oregon
