http://www.thebeachcats.c…ws/400/Soft-Deck-Repair/
http://www.thebeachcats.c…ion-repair-instructions/
Above are links to soft deck repair, please read carefully, it has pics to accompany directions, so easy even a cave man can do it. The core understanding to injection repair is to know the construction of your boat, the above repairs are done on foam core construction, an inner layer of fiberglass on which foam is laid, and then covered by an outer skin of fiberglass, glass/foam/glass sandwich. Delamination occurs when one layer of skin, usually the inner layer, pulls away from the foam. When drilling holes for injection repair, the drill bit must penetrate
only the outer skin, use a drill stop, piece of tape wrapped around drill bit to do this. Too often on this repair, do many skip this step and drill bit penetrates both outer
and inner layers of glass, letting resin or epoxy mix drip into hull interior.
In one of the above methods, the repairer uses sheet metal screws which penetrate through the outer layer, through the foam core and through the inner layer, when the screw is tightened it pulls the sagging inner skin back up to the foam layer. This method is optional but not necessary, the only pro I see to this method is weight savings, instead of filling the cavity left by the sagging inner skin, the sagging layer is pulled back up and adheres to the foam. The weight saving would be on a very large soft area, the screws would plug holes made through inner skin, but as inner skin is pulled up to foam, much of what was injected would ooze out through the other drill holes. This is where taping off the area being worked on would pay off, when repair is complete, just pull tape off.
Whatever method you choose to use, the key to injection repair, do NOT penetrate inner skin
HTH
R
