Hobie 17 side stay/base pulled out of hull
Hello everyone,
Just needing some help with the starboard stay/base that pulled out of the hull. Is this a fatal injury or can it be repaired? Any idea on cost either to replace or fix? The rear wing sleeve is leeking a bit on the same hull. I think I have an idea of how to fix the sleeve. Any help would be appreciated.
(spacecoast Fl.)
Is this what you're talking about? http://www.hobiecat.com/community/viewtopic.php?t=9293
If so, you might be able to use a drill and an easy out to remove the rest of the stud.
Good Luck
Not quite. That threaded piece and the round bar it is screwed into pulled out of the the hull.
