Hello everyone, best advice as Peter says is to learn your cat. Every cat is different, a smooth responsive handle on the tiller is always your best bet against the infamous pitch-pole of doom. My best advise even before the main sheet release, is to react instantly to the situation and read the boat's behavior through each heavy puff or sustained wind.
Learn to read and anticipate the winds on the water, look over your shoulder. What do the waters tell you? React accordingly by instantly rounding the cat into the wind a degree or two if it looks too heavy
, this can be mildly gentle with a man on the trap, or slightly more aggressive response with nobody on the trap. Saves my butt all the time. If your lee bow is skimming between life and death, come to weather a few degrees. Unknowingly to most, you are effectively de-powering your cat.
There are times when you just can't react quickly enough by releasing either the jib/main sheet to relieve the bow. However, you can react quickly enough with the tiller in hand, just a quick adjustment in most cases. Try it, save yourself the the ugly anti-pitch foils, learn to read you cat in all wind conditions and simply react accordingly--simple!
Life is better on the edge!
-Catmann
Edited by catmann on Feb 04, 2016 - 09:30 AM.
Mike
Chicagoland area
Prindle 16
Hobie 16, 18
Laser
Flying Juniors
Seatrend board sailor
C Scow
Prindle 15, 18, (current)
