While disassembling my Nacra 5.2 for some hull repair this winter, I sheared off one of the bolts holding the front crossbar (specifically the inboard strap aft of the main crossbeam). I'm planning to use a bolt retractor, but thought I'd check first to see if anyone has had any better ideas/experience.
Alternatively, I think I'd have better luck driving the remaining bolt stem past the nut and make it drop out.... does it have any room to drop out or is it in a blind cavity?
(before breaking, I was able to loosen the bolt many turns (about 1/4" gap) before it started getting tight. I worked it in and out a bit, then got impatient and it sheared off flush with the hull. ). Next time I'll use grease or anti-gall :)
Pairajacks
1985 Nacra 5.2
Corvallis Oregon
