looking to add a spin to my 18 this summer. I'd like to get into it for fairly cheap so my plan is to use sunfish boom for pole and bag launch for now. I have most of the hardware already but have some open questions.
1. Where is a good place to find used spinnakers? I've read an F16 spin works well, is that what I should look for? If I have to buy new I'll just use one of the vendors from this site.
2. Does the spin sheet ever get cleated? Looking at pics of spin setups it seems the sheet runs to a block by shroud then to block on front beam. I'm guessing this is a ratcheting block? I goes when solo I could have spin sheet in hand rather then the main.
3. How close to the wind can you sail with a modern cut spin? I mostly recreational sail so If the wind is good I'll stay on beam reach for hours on end then turn around.
