I can't adjust the mast post since the sleeve that prevents over-tightening protrudes below the crossbeam and is frozen. cannot tighten lower bolt at all to tighten dolphin striker. Its very loose with mast up so all the pressure is in the center of the beam ( NOT GOOD )
I don't want to sail the boat again until i can get things tight all the way around. Tightening the striker outside bolts by removing the end caps is near impossible being that the hull mount and sleeve block it. What are my options? Use a cutting wheel and cut the post in half then replace it and the sleeve? leave the top bolt loose so the mast forces the post downward and outward? Disassemble the entire front crossbar and remove from boat? buy a whole new crossbar from a used boat? I'm hoping to go sailing this summer without throwing several hundred dollars at it.
Any input is greatly appreciated!!
Tim Grover
1996 Hobie Miracle 20
Two Hobie 14's
1983 G-Cat Restored
