While wandering around BeachCats.com I have seen a commercially available deck for beach cats and then also just read the post from JALEX about trolling motors and the responses. Has anyone sorted out how to turn a beach cat into a rowing configuration, either with the mast in place, or with it removed. The R2AK's guys are pushing lots of human powered ideas out there, but sorting out an easy rowing conversion would add a great deal of utility to these boats, like for scalloping or crabbing here in the NW. I agree that these are very efficient hulls and could be rowed great distances with the right setup. As a rafter we simply drop aluminum frames on pretty inefficient inflated boats and often row them on flat-water some serious miles.
I was even thinking of using my 5.2 as a mold for a cat styled rowboat with some added tail ends to increase the hull efficiency at the lower rowing speeds. Or just getting an add on rowing frame made for the existing boat frame. If anyone has had similar ideas or can sketch up some concepts I would be happy to help build some proof of concept projects.
dg
NACRA 5.2 #400
This End Up
Original owner since 1975
