That is the official name for the little nylon or plastic screw that tensions the spring and plunger and cam on the Hobie 16 rudder system. Okay, as most of you know, I took my rudders all apart. I don't think the boat that I just got has had much rudder maintenance in a while, if any, being that it wasn't used much at all. The reason I started all of this to begin with was because the port side rudder was not locking down correctly and everything seemed to take more force than necessary to operate correctly. I took the port side rudder assembly apart first and found everything was dry as a bone, but it all came apart fairly easily. After inspecting all the parts, I used some blue marine grease to lube up the spring and plunger, even put some in the threads of the Delrin screw also. Then I moved on to the starboard side. The Delrin screw does not want to budge. I have soaked it in PB Blaster and I am going to try again to remove it. How would a nylon screw be so bonded in there in an aluminum casting that it won't budge? I want to remove all the parts and grease them like I did to the other side. So, my question, how the heck do I get this thing out so I can put a new one in there? Thanks for any advice on this subject.
