We have had primo sailing weather this summer. the water has been at 26C, (80F), the air temps at mid 30's, with high humidity, (90's, humidex in the hundreds), & winds, so bloody much we have stayed on shore several days.
When we stay on shore with the N5.0, it has to be over 35mph.
Three days ago the mid lake buoy showed sustained 24kts,(28mph).
We launched the 5.0, double trapped, into relatively smooth conditions, at least as smooth as you get with that kind of wind, the fetch was only a few miles.
Generally we worked upwind with crew,(me) on the wire, positioned in front of the main beam, my buddy driving, just behind the main beam. We could sink the lee hull over half way, or more, on a constant basis. We easily kept, or outdid an H17,(centreboards) in pointing.
After working 2-3 miles across the bay, we turned, & either beam reached, or broad reached back home.
At least a dozen times we buried the lee hull, once even the end of the front beam was underwater, but by both crew sitting aft, no pitchpole.
After flogging this poor boat for several hours, I pulled the GPS out of the tramp bag.
Max speed was 21.7mph.
Anyone who wants a fast, simple EASY rig, I don't think you can beat a Nacra 5.0, or 5.7, unless you buy the slightly more modern 500 or 570.
This little boat points well, goes like hell in a blow, & is very forgiving. We were way overpowered, & released sheet & car in order to stay upright. Everytime I go out in these two boats in a blow I come back wondering why I contemplate anything else.
