Depends on the wind direction.
You said landing on a beach...
If the breeze is coming from shore, sail in on a close reach, and a wave or two out - go into irons and ride the waves in. You should
already have the lee centerboard up and the lee rudder loosened.
Before you hit the beach bring up the windward centerboard and pop the windward rudder.
They are beach-able, but will last
years longer if you are kind to them.
(They are 300-400 dollars each to replace).
If the wind is from the water to the shore, consider coming in on a broad reach (with your boards up like above) and a couple of waves out, let your jib go completely and loosen your main a lot and take the shore at an angle. Don't let the main battens get bent backward on the shroud- they will break.
If you are landing on a dock, always go to the leeward side of the dock, while sailing parallel to it, let both sails out enough to slow down and then put yourself into irons to swing gently into the dock. Easier said than done.
If coming to shore is closer to a beam reach, you can de-power by completely letting the main downhaul, the mast rotator, both sheets and travelers go- then jettison your crew and all stowage but the beer. Never jettison the beer. Wait, did I say this last part out loud?
My bad.
