Posted: Aug 08, 2016 - 10:13 AM
There is usually a couple of small SS screws hold the cap in place. (Talking older Nacra, not sure what year they went to the new style beams).
If you tightened the beam strap bolts down more than spec,(18 ft/lb), you may also have compressed the slot the tramp sits in, & also compressed it onto the caps. You could loosen the strap bolts,(they could probably use some grease anyway).
The simplest solution is a store like Harbour Freight, (or Princess Auto if you are in Canada), & purchase what is called a fish tape. They are under $10.
Feed one end through, then you might have to use a short piece of bent wire at the other side to pick up the business end of the fish tape.
Edited by Edchris177 on Aug 08, 2016 - 10:18 AM.
