Hobe 17 - separate hulls from front and rear beams
Hi All,
How do I separate hulls from the beams on a Hobie 17?
How much efforts, don't want to damage anything...
Ideas, photos, manuals etc. are very welcome.
BR
MCTG8
MN3what are your goals?
http://static.hobiecat.co…94.1403889916.1471875580
Thanks!
Goal is to check for any cracks and structural problems.
I've seen the attached manual, but is it really just one socket set screw + anchor bar per side and beam?
//MCTG8
Quotebut is it really just one socket set screw + anchor bar per side and beam
I've owned a h16 and h18 but never a 17 ... i will leave it for actual owners to comment...
and i couldn't see clearly in that manual .. worst images ever (was it illustrated with stone and chisel?)
Some General Tips:
I would use penetrating oil ahead to assist of release
if the bolts squeak - stop don't heat em up - go slow
use a product on your bolts before you reassemble - i swear by Tef-Gel
Edited by MN3 on Aug 22, 2016 - 01:04 PM.
Agree, hard to tell from the pictures. But OK, I understand how it's set up.
