Posted: Sep 29, 2016 - 09:29 PM
Go to page 4 of the "parts for sale "section and find "Nacra Clearance Parts Sale". Those parts are from NACRA USA. About 20 items down the list is a couple of masts that may work on your boat. That's assuming that they are either not drilled (blank). Or are complete(not likely. ) you may have to buy a new mast base because the mast section is likely different than yours. From there, take all of the measurements of the previous locations of hardware, switch everything over. It's a lot of work. Also, due to the different bend characteristics of the Ali v carbon mast, your sail may not work with it well. But the good news is, if you're not in the top 10%of cat sailors, it probably won't matter much.
I know this sounds pretty simplistic, but the only way to do it is to jump in and do it yourself or pay someone that knows what they are doing. There is no short answer to this one. In fact, you could find a mast from an old N6.0, 5.8 and make it work. ive seen a Hobie 18 mast and boom on a NACRA 5.0. I'm not going to tell who came up with that one;). We called the HOCRA. BLASPHEMY!!
Don't drill unless you know it's right. Don't cut and less you know it's right . Make sure everything sealed up when you put it back together . Take some Tylenol before you start because your hands are going to be sore as hell by the time you finish .
