What do you guys think about fixing, with rivets, a swivel cam block on an Inter 20 carbon mast to raise the spi? Is, in your opinion, the structure of the mast strong enough to sustain the stress of the sail?
Thanks in advance.
I too contemplated this... At the time the factory was local to me and I had asked the opinion from them... it was not recommended... They were experiencing some issues with the rotator bar with elongating holes and becoming lose, and thought this would put a similar bouncing pressure on the mast creating an identical problem... hence the upgrade to the F-18 style mast base. As per
I changed it over to a system using one of these... it never got jammed up after that
