The trailer, as shown in the photo is not wide enough for a Cat. Dan may have the X beams removed to save space.
I have one of those Trailex trailers, very light, one person can pull it around, with the Cat loaded, & no corrosion issues.
If it doesn't come with the beams, you will need to add them, & will want cradles for a A-Cat. Trailex has used the same fittings for ages. Their X beams are simple pieces of the same extrusion the frame is made from, & are secured with the same fittings that hold the trailer together.
You will also need a mast support on the tongue. Again, same extrusion with one of those "V" blocks on top to hold the mast. Mine appears to be a "V" block used for the bow stop on other boat trailers.
The ones in Dan's photo were used for narrow boats, you can see the bunks & rollers. The good news is the fittings they use for the winch can be used for a mast support, you just need a length of extrusion. The angled fittings to the side of the front roller are what mine uses to secure the cradles.
The genius of these units is how easier they are to customize. All fittings can be moved by simply loosening a captive bolt,then sliding the fitting along the dovetail in the extrusion, then re-tightening bolt.
Here is a quick album I threw together, sorry, i can't make the 3 sideways photos rotate.
http://www.thebeachcats.c…ictures?g2_itemId=126053
They are easy to re-wire. Either run wire inside the grooves & tape every few feet, or fish it through the frame.The latter is harder, as you have to undo the fittings where the frame narrows to get the wire through, but it's then protected. Buy decent tinned marine wire, more $, but lasts.
Talk to Dan, he may have any extra pieces you need.Rest assured he is an honest stand up guy. I once purchased a Nacra spreader bar that turned out to be seized. After trying his solutions to free it up, he refunded the full amount, no questions, no hassles.
Edited by Edchris177 on Nov 22, 2016 - 12:17 PM.
