Hi Damon,
Mast is... 9.5m / 31f. The mast has a captive ball, similar to a Hobie Getaway. When the mast is down, it "slots in" with the mast rotated 90deg. There's no hold-it-in-place mechanism (as seen on the H16 vid), I hold it down manually. Once you get the mast up ~30deg it stops wanting to snap out, and it can rotate to its normal position.
The manual explains the process clearly, but not "efficiently", it shows 4 people around the boat in a picture. Not surprisingly, with 4 I can get the mast up just fine, but I can't always corral such a crowd, and that H16 guy did it solo, ffs
You're right I haven't sailed a modern high performance boat like a 470.
I have sailed a Dart 16 on the wire, singlehanded (for some reason, I end up sailing lots of UK designed boats
), to the point I bought my own trapeze harness. I have no problem with the transition from sitting on the trampoline to being on the wire. Overall power/weight ratio however aren't all that exciting on the Dart 16 without a spinnaker (that's how I sailed it).
Of course this boat has a learning curve for me. That's why I'm posting here
and that's half of the fun anyway. Crew has very limited experience on these kind of boats.
On the upside...Biscayne Bay is mellow and forgiving, I know it inside out (tilled it on Hobie Getaways, dinghies and on a 41ft keeler), and my crew are crazy enough to sail with me. If I stay with what I know, how will I learn something new and exciting?
Cheers! ~martin
