Posted: Nov 30, 2016 - 01:19 PM
Hello,
Just my 2 cents here to give you more options and possibly a longer lasting result.
You could also add some external "core" and carbon over that for a stringer effect. This core could be a long thin piece of corecell or divylcell with bevel edges or better yet a carbon tube that would distribute the load further - ($16 on eBay). The big thing is just adding a little extra contour for the carbon to do its job. Note this approach will require some fillet bog to accommodate the curves and while epoxy/micro-balloons would be best an epoxy putty would work fine. In this situation, depending on the size of the void to be filled between carbon pole and stringer edge and I might not even hesitate to use bondo as a minuscule filler since I would be wrapping with carbon/epoxy but if using going this route I would precoat with epoxy (Epoxy is chemical bond, Bondo/Polyester is mechanical bond).
With carbon I have found very little difference with vacuum bagging and really aggressive compression/squeegeeing especially on a very small job such as this. To best accomplish this I do recommend you use peel-ply also known as vacuum bag release film and you can cut this into thin strips and wrap tightly achieving the same result as using electrical tape w/holes (Again see eBay). Another advantage of using peel ply is that it leaves the surface ready for additional epoxy bonding or painting although I always sand and acetone anyway.
Best advice I can give is over prep (sand/acetone) surface and have all materials prepared in advance. It is even a good idea to do a walk through.
James
H17+ but more importantly, 2 refurbished F25Cs.
