Sailing a Whisper cat, I need to run a dyneema line that gives strength to the spinnaker pole through the eyelets of two dolphin strikers,
These dolphin strikers are wing-shaped (elongated, length-wise), about two inches long. The piece is carbon fiber, but the eyelet is in a plastic part... the hole is way too narrow for the line, and the line needs to go through around 2 inches.
I've tried very wide masking tape, pushing, pulling, screaming... what's your best trick?
