Posted: Apr 17, 2017 - 01:42 PM
I run HM dyneema on my beachcat traps. There are a few ways to do things but this is what I can say from experience:
1) You want normal line cover over the dyneema anywhere there is a chafe point, which is normally at the top of the mast right below the thimble and bottom where the adjustment cleat is. You also want to keep an eye where the trap crossed the shroud lower down when you are trapezing aft on the boat
2) You splice, no knots on the lines period. I prefer to splice the crew and skippers trap lines to a single thimble on each side.
3) At the top, you can attach to the normal trapze point with thimbles, or, which may be better from a chafe standpoint, you can attach the traps to the eyelet in the standing rigging using a soft shackle. This is more pro-level stuff and it requires you to have a good set of terminations on the standing rigging like the latest hydraulically swaged thimbles Nacra are using.
4) I use 7/64" line but if chafe is a concern 1/8" is fine, this is still lighter than stainless trapezes and if you are racing, weight counts.
Full wire trap lines are probably better if you are distance racing and don't have the opportunity to check your traps for wear regularly, I'm usually mast down once a month so can do a full line inspection while I'm coiling.
