http://www.apsltd.com/ang…ser-15-degree-micro.html
small cam cleat riser.
Question is I'm wanting to add a cleat on my beam, but at an angle so I considered customizing the base of this riser to suit the curve on the beam. the location would require a compound curve so that is not going to be a standard cured base...which I don't even see for harkens small cleat (H468)
Question is, what does the bottom look like. is it solid? can is safely be ground down to fit your needs?
thanks
1988 Nacra 5.2
YouTube link to see boat in action:
https://www.youtube.com/playlist?list=PLddinE6IorSrPpZrlvcwAjRzSIQsKYPG1
