3D Printed NACRA parts
Hi all,
I have a small aerospace business that has been using 3D printing to prototype aircraft parts, and with the recent purchase of my NACRA 5.7 and its subsequent restoration, I have started 3D printing parts that need replacing...
My first project was the mast ball, and I printed a new one with 80% Nylon, and 20% carbon fiber...I'll be testing it out in the weeks to come, and I'll give you all some feed back on its performance!
Any other ideas or suggestions for things to print or that others have made for their boats?
https://www.instagram.com/p/BUKVAnIAUwa/
Eric
1986 NACRA 5.7 #331
I fly seaplanes...and a cat on weekends
upper and lower castings
tiller arms
goose neck
rudders
centerboards
fem-bot crew
Beam end caps. Rudder adjustment screws.
Yea beam end caps with like a 1/4" hole with a beveled radius so people can pass a downhaul line through the beam.
End caps with wing seat attachment points or holes.
I 3D print all the time for work (medical implants), mostly PLA or 17-4 SS. I have heard of carbon becoming printable. Is is normally a robust material. What brand printer do you use? Thanks, John
Hi John,
I've been printing with Kevlar, Fiberglass, Nylon, and Carbon Fiber for some time now, (with an Ultimaker 2+ Extended (with Olsson Ruby) and a MarkForged Mark One Professional) and they are extremely strong. The Ultimaker 2+ is my current printer I use and has been upgraded to an all-metal hot-end, and a special nozzle that can print abrasive materials, such as Nylon and Carbon Fiber. I've had quite a bit of success printing parts for my boat so far, and highly recommend that you look into it. PLA won't be up for the task in most of the things you need, but it's relatively inexpensive to upgrade to other materials!
The end caps and rudder adjustment screws are a great idea guys and should be pretty easy to make...I'll print myself some, and then put up some photos of the end result, and give you all some feedback on testing!
Example of the mast ball for post 1983 NACRA's...
http://www.tempestaerospa…re/products/show/7475581
Edited by sea_flyer on May 17, 2017 - 04:03 PM.
Eric
1986 NACRA 5.7 #331
FWIW, the standard ball will last forever if you bed it in the casting with Marine-tex.
Wax the ball with a couple of coats of your favorite polishing wax. Mix up some Marine-tex, put a blob in the casting and press the ball in, and tape it into place. Before it hardens, scrape out the excess marina-tex that has oozed around the ball. You only need a smooth bearing surface on the top of the ball. After it has cured, pop out the ball, screw it onto the stud, and go sailing. Do this with a new ball, and you'll never have to replace it again.
I have an stl file for a Wave end cap for back rests. You could probably sell lots of those. I will forward it if you want to try to build one.
Hi John,
Sure that would be great! If you want, you can email it to me: tempestaerospace@gmail.com
I just made one for my NACRA 5.7, and it is printing right now, so I will let you all know how it turns out!
Eric
1986 NACRA 5.7 #331
do you have the ability to scan stuff - then duplicate with the 3d printer?
If you made rudder cams, I think there are 2 sizes. One for the 14/16 and one for the others you'd probably sell a bunch. The hole is always wallowing out from grounding. Probably the most replaced part. If you did that same nylon carbon mix or just something strong it would be legit. Don't make them hollow on one side like the current ones. Just beefcake
sea_flyer is any of the print medium UV resistant? I had someone print up a bracket to hold my wind vane, and 8 months stored on the tramp broke it down. I had to make a replacement from UV stabilized Delrin, using the table saw and drill press.
Hi,
I have been meaning to sort out making some end caps for a long time, I would really appreciate it if you could please share the design?
Anthony
Hey guys,
I've actually had success printing the beam end caps, rudder set screws, and am working on some other components...I'll post some photos of my progress later today.
Klozhald, as far as UV resistance goes, I'll be doing some extensive testing on this...NylonX is a new material, and there really isn't a ton of data for it, with regards to UV resistance...My boat is outside all the time, and is in Florida, so I should be able to give you some good feedback with time. I think that with the combination of both Nylon, and Carbon Fiber, it will probably do better than most, but how it compares with Delrin, remains to be seen...I'll keep you posted!
Eric
1986 NACRA 5.7 #331
MN3do you have the ability to scan stuff - then duplicate with the 3d printer?
That rarely works out. Converting a point cloud to solid model that can be printed is time consuming work. I suspect the software and the scanning system will get better as time goes on so in even 2 years from now my comments could be out of date, but for most of the parts we are talking about a pair of calipers and some engineering paper work wonders.
What about printing big stuff like rudder castings. Might have to beef up some areas or just design your own style that fits existing rudder mounts. They are pretty expensive on all boats and over time the supply is only getting smaller.
QuoteThat rarely works out. Converting a point cloud to solid model that can be printed is time consuming work. I suspect the software and the scanning system will get better as time goes on so in even 2 years from now my comments could be out of date, but for most of the parts we are talking about a pair of calipers and some engineering paper work wonders.
Please 3d print a time machine - go to the future - bring back a REAL scanner so i can scan my boat parts for 3d printing - while you are there please grab me a Star Trek lunch computer so i can have lasagna or pizza within a few seconds at any time
your assistance is appreciated - feel free to 3d print up some money as thanks from me!
QuoteWhat about printing big stuff like rudder castings
I just purchased a new set of uppers from Mystere (1 of them was poorly cast and i asked for replacement)
funny - at the same exact date this thread was posted our friend Paul (guy who was camping with us last fall on the P18-2) sent me a text with images of his new 3d printer. I asked about castings - he said "no" lol
Rudder castings are exactly as stated, cast parts done in aluminum. There are many issues with this (no casting is ever 100% the same as the next, and some contain defects), but its a relatively cheap method to fabricate parts in volume with reasonable consistency. As CNC machining has come down in cost, some manufacturers (Goodall) have switched to that, which leads to higher consistency in the parts as you start with a pure base metal. The reality is these parts are not that expensive. Go and price some custom machined parts, or even volume machined parts, with similar specs:
Multiple holes located on different faces to under 0.005" location
6061-T651 aluminum or equivalent
Type II anodized finish
Good luck at matching casting price from a dealer. Even a carbon filled plastic 3D printed part would fail in a new york minute the first time you tried sailing with one. You need titanium or maybe aluminum 3D printing and that is expensive with long print times. Even on a home printer you are looking at overnight runs.
I used to work next to a company that had one of the metal printers that would laser a metal dust bed and essentially weld together the model. Something like that could probably make a product as strong as a cast. Even with the carbon printer if enough material was used it seems like a reasonable strength thing to make. Maybe use stainless sleeves where the mounting points are and I'd think it could hold
Samc99us,
Believe it or not, Matterhackers, the company that created the NylonX filament, states that it is a potential replacement for aluminum using 3D printing instead of CNC. This stuff is unbelievably strong, especially when it is printed dense, and I'd be willing to bet that if designed properly, it could hold up to more abuse than a cast part...there is definitely a lot more flex in the material, despite its density (which prevents the shearing or breaking we see in cast parts). If you're into the sort of thing, I have provided you a link with a spec sheet on the filament, just to give you an idea of its properties:
https://www.matterhackers…QUun1GXGpdZ4UyfYAkvnAKdI
As for scanning, it is possible to scan and print something extremely accurate, but the problem is the cost of the scanner...at that level of precision, you can start at $9,000, and go up to north of $100,000 for a handheld scanner...
Tamumpower1,
I am actually working on creating a set of rudder castings with NylonX, to see if it is viable...I have a design already created, but I will obviously have to print, and then test them to see how they perform...I definitely don't mind field testing stuff, so I'll give you all the feed back...
Eric
1986 NACRA 5.7 #331
As promised...end caps and mast ball...
I used calipers to measure existing parts, and then used Autodesk's Fusion 360 software to design the parts...then sent them to the printer...these are made with the NylonX material we have been discussing...
http://www.tempestaerospacelimited.com/IMG_1385.JPG
http://www.tempestaerospacelimited.com/FullSizeRender%203.jpg
http://www.tempestaerospacelimited.com/FullSizeRender%207.jpg
Eric
1986 NACRA 5.7 #331
Let me know when you have yours - i am ready :)
QuoteAs for scanning, it is possible to scan and print something extremely accurate, but the problem is the cost of the scanner...at that level of precision, you can start at $9,000, and go up to north of $100,000 for a handheld scanner...
Edited by MN3 on May 24, 2017 - 04:50 PM.
Thanks for the data sheet sea_flyer. FYI, That tensile strength number for the Nylon X is 3.1 times weaker than 6061-T651, and the tensile modulus is 10 times lower with corresponding increase in flex. This flex translates directly into helm feel and thus speed. Not a good thing in this particular application; please note this is why EPO rudders blades are all the rage on H16's/H18's and the plastic ones are considered mediocre especially for racing. Your Nacra 5.7 has fiberglass rudders blades that are of comparable stiffness to the aluminum castings, which means well balances strain rates. Using a plastic casting is thus transferring some load back to the rudder head and you could be asking for trouble when that shears off.
Also please note your concerns about flex and shearing in a cast part translates directly to a 3D printed part, if not more so. These parts rely on fusing between layers, and often that is the failure point, not the material itself.
I have limited access to a >$100k SLS 3D printer and it can come close to machined nylon in final part specification, but again this is nowhere near the properties of even lower grade cast aluminum alloys (https://en.wikipedia.org/wiki/Aluminium_alloy#Cast_alloys). If you do go ahead with this, I would print the part such that the sides are flat against the build table, thereby putting the grain at 90 degrees to the shear loading on the casting and reducing that failure mode. Good luck.
P.S: I do think this is useful tech for a lot of parts like the mast ball, end caps, some adjustment screws, possibly the bearing surfaces in newer Nacra rudder parts, stopper balls, lightly loaded latch mechanisms etc. Home 3D printing just won't replace aluminum parts today, but I can see it getting there in another 10 years (some patents have expired that may alloy this). Home CNC machining is there today however :)
Edited by samc99us on May 24, 2017 - 04:18 PM.
Samc99us,
Definitely some very valid points/concerns. My original plan was to just print smaller replacement parts for the items already made in delrin, plastic, or nylon, but since the rudder castings were suggested by some other members' posts, I figured I would try it to see if it can be done.
I liked your suggestion about printing it flat against the build table, and plan to do just that. I also plan to use a random/tetrahedral infill pattern, which will definitely help with the strength and any tendency for shear to occur. I have seen some other cats use carbon fiber castings, with carbon fiber rudders, and I wonder that if I print these, perhaps I should switch to a lighter set of rudders? I'm mainly looking for something with a better performance/weight ratio.
I'm definitely not afraid to try out stuff for the sake of science and learning, so I'll be sure to give you guys some more feedback as I progress. If you have any suggestions, please continue sharing...I'm definitely open to those!
Eric
1986 NACRA 5.7 #331
sea_flyerAs promised...end caps and mast ball...
They look great! Would you be willing to share those designs with us please? I appreciate that you spent time and energy creating the designs so I absolutley understand if you dont wish to do so.
Thanks, Anthony
sea_flyer,
Switching to a lighter set of rudder blades (carbon) isn't going to help the situation. Carbon is significantly stiffer than glass or nylon (its close to that of steel, and can exceed it if it's a high quality aerospace pre-preg built with expensive high modulus fibers) and will transfer all the rudder load through your castings to your pintails to the transom of the boat. Personally I wouldn't waste my time trying to print a set of castings. Maybe if you use your Marked Forge and did it in 3D printed full carbon you would get someone reasonable.
You would have to build something on the order of double the thickness of the original castings to even get close to aluminum using your NylonX material, even at 100% infill. FYI, I've printed with most of the materials you are playing with, and have run print jobs in excess of 36 hours on a consumer FDM machine-we were on a deadline to get to a test event and it was the only way to get some fairing parts done in time. They are not the same, even the carbon impregnated variety, as the SLS nylon prints I do somewhat regularly. None of these compare with aluminum in terms of stiffness or strength. I'm not sure how the Marked Forge prints compare, but they have some big name sponsors and users and I suspect some MIT grads working for them, so I suspect their Oynx parts are up there.
Out of curiosity, what kind of price-point would the end-caps have to make it worthwhile printing some?
We could just take the 3D printed part, cut it in half and use it to make a sand mold then slap a little molten aluminum in there. Everyone's got a backyard foundry right...? Would only need about 1300 degrees F
Samc99us,
Definitely great info, and thank you for sharing your experiences...I think the biggest problem I would have printing the rudder castings is the sheer build size...neither one of my printers has the build volume necessary to print one in one piece. I did successfully design a set in Fusion 360, but I just don't have the volume to print them. Some of the newer MarkForged printers could do it though...I'd be especially interested in the Onyx...I've looked at upgrading my printer to the version capable of doing Onyx, but there is a wait time, and considerable price attached, so I don't think I'll be able to try that until later this year, when I have a month to spare sending it in.
Aquaddict,
I'd be happy to share the .stl file with you...if you'd like to shoot me a PM with your email, I can email it to you.
Tominpa,
I'm able to print a set of these end caps (2) for about $10...extremely reasonable...they take about 2-3 hours to print. Definitely worth the effort, IMHO.
Eric
1986 NACRA 5.7 #331
I just got my folgertech FT5 up and running and have a 34+ year old G-cat. Ancient castings are only 1 of many projects i am considering. with a 12x12x16.5 inch build volume this thing is amazing! Retail kit is like $499 BTW so not crazy expensive. New filaments are coming out every day that have some pretty amazing properties. i recently found a "print and bake" aka annealing filament that may well exceed aluminum castings when they were new and didn't have a dozen repairs LOL. You are spot on in print strengths being related to orientation during print but i believe this tech may alleviate that issue altogether. If you are willing to share your STL,s I would greatly appreciate it. I will certainly do the same but am not at all familiar with cad yet so tinker cad is about all i can handle at the moment. you can reach me off list at pds624@gmail.com oh and i see your boat but what kind of printer do you have? :)
Edited by PAUL624 on May 25, 2017 - 08:20 PM.
tamumpower1We could just take the 3D printed part, cut it in half and use it to make a sand mold then slap a little molten aluminum in there. Everyone's got a backyard foundry right...? Would only need about 1300 degrees F
they have dissolvable filaments too so perfect for 1 piece molds. no need to cut things up and put them together again...
Even if you have the build volume, prints like this take a significant amount of time. Time is money (in the real world, I would estimate a 3D printed nylon rudder casting is on the order of $800-$1200 depending on turnaround time and vendor). You aren't going to be able to compete with production castings at home in your garage. 3D printing is nice for iterating through prototypes or fabricating extremely complicated shapes that would otherwise require 5 axis machining. Its coming along to where it may replace castings and metal parts in certain applications, but not all. Every technique has limitations, its knowing those limitations that pay big $.
The end caps are nice, as you can custom print your own with different holes for various control lines.
yes, printing anything of size and hi res takes time. i did a print recently that was about 15 inches tall and 5x5 took 47+ hours to complete ugh. that said, it took about 10 minutes to set it and forget it. The waiting is the hardest part LOL. For me 3d printing is both a hobby and a tool. Being able to go from idea to finished part in the same day is awesome and my house is slowly filling with little life hacks at no extra cost. My nephews are another story all together. they run print farms and have literally made millions off this tech. It is possible to turn a profit but certainly not easy. i would estimate 95% of the time is cad design. My printer kit was 500 bucks and i got some amazing upgrades for another 1000. total investment of less than 1500 for a machine like this would easily retail for thousands more as a finished product. I can print pretty much everything but poly-carbonate now. That upgrade would cost me about 50 bucks but i dont currently see a need for it as the new materials don't need 300C temps to print. considering the endless applications, you cant beat the bang for the buck no telling how much time and money this saves me in the long run. I am well versed in glass work and can tell you for sure and for certain this is way easier and far less toxic to work with! BTW, DARPA is currently working on a moon base concept for a 2020 mission to bots and 3d printer will build the base. You should also check out the tech behind 3d printed cars. industrial size machines that can make anything. The russians have been 3d printing structures in concrete for years. Yes there are UV stable and temp resistant materials coming out every day. PLA is cheap and eco friendly so good for test prints at a minimum. this printer tech has been out for a long time but IMHO the filament market is where the magic is happening at the moment.
Quotei did a print recently that was about 15 inches tall and 5x5 took 47+ hours to complete ugh
sounds like my first renders in 3d studio max a few dozen years ago.
they already have cell phone apps that will render 3d... not long now till quality scanners are available at reasonable prices even to us lowly end user\consumers
Great thread!! Keep it up guys.
You need to make the larger 1.5" ball with the old nacra thread on it. I'd buy one. That way for me to update to a captive system I don't need to get a new dolphin rod to accept the newer ball.
Any chance of 3D printing a mast cradle to fit the rear bem with traveler rail, and mast radius? I'd love to have something for the 5.7. If you make it, we will buy.
Edited by tominpa on May 31, 2017 - 12:02 PM.
sorry guys but i dont have time to do design work. get me and stl file and i will print it at cost for friends no problem but i have a 34+ year old g cat so cant buy parts and have a list of things yet to design there already LOL
Quotei have a 34+ year old g cat so cant buy parts and have a list of things yet to design there already LOL
You should print a skipper that will sail more than 1 time every 8 months!
And print me up some of your eggs Benedict too! i am hangry!!!!
well you can eat those chops you just busted LOL
lol
sea_flyerSamc99us,
Aquaddict,
Hi,
I sent you a PM, not worries if you have just been to busy to send the stl files, just following up in case you didnt received the PM or your email went missing.
Many thanks,
Anthony
i would luv to get my hands on some 3d parts files. If you all are willing to share. I will gladly be custodian and offer them up free to all that want them. Not looking to make money here just support our hobby\passion...BTW, some of you may know me as the guy who digitized and uploaded all the G-Cat data a couple years back...hows that for street cred? LOL Maybe our good host will start a section for them as well as i do believe this is the future. I just got 2 rolls of thulman alloy 910 so need to do some design work before i can do anything practice with it as far as the boat projects go but will be making upgraded parts for my printer from it ASAP.
Beach Wheel Parts like non boat specific basic cradles.
Edited by Quarath on Jun 13, 2017 - 02:01 PM.
Is the original poster still on here? I sent a message a few weeks ago and never got anything back. Was curious what file type you needed for the printer. stl, g code, etc
Hey Eric,
I've started modeling a new foil bottom bearing (modeled after the N17 replacement bearing) for my A-Cat. Would you be interested in printing them for me? The nylon / carbon is exactly what I'm looking for. Shapeways, Stratasys, et al don't seem to offer a composite option yet. Name your price or I could offer some 3D modeling in exchange?
thanks!
daniel
RE: 3d scanning - photogrammetry can get you shockingly close, with some re-modeling and calibration with physical measurements, which you have to do with laser scans anyway. Happy to give it a shot if you have a part you'd like to replicate.
