Not a motor guy, but when I have the girlfriend and the dog I want be able to get home if needed. I like the idea of the Lehr propane outboards. Seems clean and easy, I've read some mixed reviews. Sounds like they are still ironing out some issues. I find propane engines are typically easy to start and reliable, as far as forklifts go at least. What else are people using on cats?
I've got the cheetah mount, came on the boat. Looking for what's super reliable and easy to start. I can't imagine trying to yank a pull chord leaning over the rear cross bar in a seaway. I may justify spending 2k on the torqueedo but I doubt it, not to mention $600 for a spare battery, although if I was looking to save money I probably chose the wrong hobby
I have a tohatsu 3.5 that was purchased new a dozen years ago to be mounted behind a g-cat
it was probably only mounted a dozen times by the previous owner
hardly used until 8 years ago when i purchased it for my jon boat - used a lot around thanksgiving every year (when we camp)
has been incredibly reliable
now in an ama on a f31R trimeran to be used as a dingy engine on a porta-boate
Um, these are sailboats right? Believe me, I know what it's like to be caught in the doldrums but, wouldn't the extra weight of a motor just really slow your sailing down? I don't like the idea of mounting a motor on a beachcat, but that's just me. I've seen it done though. The only advice I have here is to use a paddle.
-- Marty
Opelika, Al / Lake Martin --
No beach catter likes the idea - but sometimes it is needed
i.e. when your only ramp is into an unfriendly canal or area with strong currents
or you have a young kid on board that you can''t risk getting stuck out there with
or you have a wife/gf/etc that can not get stuck out there
I personally was 4 or 5 hours late to a thanksgiving dinner when the wind died - I am not sure the wife ever forgave her husband (the skipper) - that was the last year i think he held on to that "early t-day sail" tradition
PS yes, an additional 50 lbs or so hanging off your rear beam is not optimal for your sailing
I've used 2 to 3.5 hp two stroke outboards on 18 to 22' cats for years. It is weight aft, which is less than desirable, so look for the lightest(smallest) short shaft motor you can find, most are in the mid 30 lb range. I did try a Honda 2 hp four stroke once, but it was heavier than equivalent two strokes, and produced a lower top speed, maybe 4 kts on a SC20. Was much quieter though. When I motor out to the main lake for my morning sail (10 minutes) solo, I use an ipod with headphone like ear defenders over the earbuds. And I fabricated motor mounts that allow the motor to tilt up far enough to get the lower unit horizontal, dragging it in chop is really unacceptable. This extra weight aft can be compensated for to some degree, by moving crew weight forward. I had a 2 hp Evinrude on an H18, and that was the smallest boat I'd consider putting an outboard on, and it's low rear beam made it tough to keep the motor out of the water when sailing. The Supercat 20s, and the ARC 22 handle the weight of a 3 to 3.5 hp motor fine, and they will generally cruise at 6 knts in flat water. If it's blowing hard, you're better off sailing than trying to motor in a big seaway, it may not be enough power to keep the bows from blowing off your desired course, and tough to keep the prop in the water if the boat is hobby horsing wildly. Like all small engines, keeping it in tune with fresh fuel, goes a long way to getting it to start reliably. I usually shut off the fuel while still motoring, til it runs dry, tilt up to sail, and open the petcock when the motor is lowered again. This minimizes flooding and hard starting. Drop the motor and get it running well before you need it, to stay out of trouble if it doesn't start quickly. Only buy a motor that starts on the first or second pull.
Adding an outboard adds a degree of complexity to catsailing, but can get you out on the water much more if your launch is in a protected area, and it allows you to venture further from home because you're not fearful of getting stranded if the wind dies. I sail a lot on Flathead Lake in NW Montana, which is a big mountain lake that often has thermal winds blowing nicely on specific bays at certain times, even when high pressure leaves much of the lake like glass, and I'm often willing to motor to wind, play for a couple hours, and motor home if necessary. Increases my glee factor significantly over time.
