Posted: Jun 24, 2017 - 04:15 AM
I have got a Prindle 16, all in good shape except the top side of the hulls are soft under the trampoline. I have read a lot of the forums on fixing the problem by injecting resin into the hulls, between the inner and out layers of fiberglass. My only problem is knowing what resin to use. What kind of foam core is in the Prindles? Can I use polyester resin? or should i use Epoxy resin? I don't want to melt the foam in my boat, but I am also looking to spend the least amount possible on this repair. The polyester resin is much cheaper than the epoxy. I know epoxy will work, but if I can get away with using the polyester resin, I would be stoked. Thanks.
