What Sam said is pretty much spot on and aligns with our observations.
We don't tow more than an hour or so with a tilt trailer for a couple of reasons; fuel economy sucks, it can get swirly when it gets windy and it's hard on the boat. When you take the tramp off to make it more stable, the boat loses a lot of its stiffness, so racking is worse. Think about how many times you hit a bump going down the road, the boat is going to flex just a little every time.
Putting it on and off the trailer isn't bad so long as your trailer isn't too tall and the tilt mechanism works correctly. However when you want to put the cover on, take the cover off, get to some hardware, etc. you have to either get out a ladder, or drop it down.
Don't get me wrong, a good tilt trailer is awesome and saves 60-90 minutes rigging and de-rigging. If I'm going to have to remove the tramp, going the extra step and pulling the beams isn't but another 10 minutes or so. To fully remove the tramp requires removal of hardware that would take longer than just pulling the beam bolts; I'd rather do that than have my tramp wrapped around the beam and flopping in the wind while driving down the highway. My boat has never to my knowledge been on a tilt trailer and I think that is a good thing.
Honestly though, this is part of the reason that I just sold my T. I LOVE the boat and have yet to find something that drives as nicely, but when you watch F18's show up after you and are ready to sail before you are... and the same thing happens when breaking down, your wife says, "let's get something easier" and she is right in our case... well, and our team has other reasons for freeing up the slot for a different boat
Regarding more mast on the T; that's an interesting subject. We've put an M20 mast on the T and it works well, with some caveats. First, the boat just doesn't have enough board to offset the additional sail area when in light conditions. Once the breeze is up a little, it does well, but it exaggerates the need to foot on the T even more than on the stock sport rig. I've designed and partially built a drop in insert so that you can use daggers to alleviate this problem, but have not finished or tested them. Since I've sold the boat, doubt that I'll continue forward, but who knows.
The other problem is the lack of forward buoyancy; in the 2016 FL300, we couldn't push as hard as we needed to. In 2017, we ran the boat with small t-foils on the rudders and it made a HUGE difference in stability and surviveability.... until we broke a rudder.
I guess one additional problem is the lack of adoption of SCHRS in the US; people/organizers/USSA are stuck on the old,
DEAD DP-N system where modifiers have no base in reality. Racing in what we called the "big rig" configuration caused problems where we would be given an unrealistic rating that the boat could never meet. I mean, really, we owed the N20c time!
Edited by wlrottge on Jul 10, 2017 - 05:50 PM.
