I have recently encountered a sail where this is not the case. The back clew plate hole is astern (in back of) the mainsheet traveler track even with the mast straight up (no rake). This means that you would pulling no tension at all on the foot and in fact be compressing the bottom batten, when close hauled. I don't think this is correct and would like to check it.
If some of you would be so kind please check the dimensions A and B shown in the pic below and post your findings here. Please also note the loft that made your sail and it's approximate age.
A: the dimension from the clew plate middle hole to the back hole (center to center).
B: the dimension from the back of the mast luff track to the center of the middle clew plate hole, basically with your sail up hook a tape over the front edge of the batten cap and measure to the center of the middle hole.
The second pic shows my sail and the sail in question on my boat. The mainsheet system is hung in the rearmost clewplate hole on both sails.
Further I welcome any comments relative to boomless rigs on other boats and whether the clew plate location arrangement I have outlined above is correct.
Thanks in advance.
Edited by leeboweffect on Jul 23, 2017 - 03:17 PM.
