seems you would want to move the clew inboard with the side to side lead & move the fore aft adjuster rearward for heavier air making the jib a bit flatter, but the manual is a bit different.
The barber hauler outer positions for down wind
Here's the full directions
FOUR-WAY JIB SYSTEM
The optional four-way jib system has a few
basic positions and infinite options in
between. Use these basic guidelines to discover
your preferences.
The four and aft track:
Set at center position for light to medium
air.
Set at aft position for heavy air.
To side to side lead:
Set at 8” inboard in light air.
Move position outboard as wind picks up
until lead is about 2 to 5 inches inboard
when you are a little overpowered.
You may find in certain downwind conditions
that having the barberhauler (option and
seperate from the four-way jib system) all
the way out is too far for proper wind flow.
In medium to heavy conditions setting the
barber 8 to 15 inches from fully outboard is
optimum.
