Just went online to Murray's. They still show them available. Here is the part #'s.
Product Description
Contoured 4″ hatch 2-Port Kit
Each Contoured 4″ hatch 2-Port kit includes two deck rings and two lids. The deck ring has a contoured (curved) surface for leak-free installation on a curved deck. The kit includes two ports (hatches), nylon fasteners, silicone sealant and instructions. Cat Bags are not included.
Use this page to order hatch cover kits:
#01-1164BK Black; Compare to Hobie Cat® #5352B.
#01-1164WH White; Compare to Hobie Cat® #5352W.
Contoured Port Rings:
The underside of port deck rings are contoured to approximate the symmetrical “dome” shape of decks on most Hobie Cats, NACRAs, Prindles etc. That curvature is not perfect for all catamarans, some care must be taken to shape the deck or fill/bed the ring with sealant. Distorting the ring shape to fit the hull will not work. The port will fail to seal properly.
Edited by saltlife77 on Oct 26, 2017 - 08:23 PM.
-- Pete
2001 NACRA 450 SOLD
2000 NACRA 500 TOTAL LOSS
2004 NACRA INTER 20 SOLD
2016 NACRA 500 Sport
DeLand, FL --
"This product is currently out of stock and unavailable."
But dude thanks for the effort! I have googled them to no avail. I will call Murrays tomorrow and check on when they may be available again . Thanks again. George
-- 2016 Hobie Getaway
1978 Nacra 5.2
1978 Hobie 16 (back in the day) --
Theres a dude selling non contoured ones on ebay for super cheap. Got some and they are viking brand. They work fine for the front ports. I just used a bunch of sealant under the sides for the small gap. The ones near the dagger board and behind the rear beam its too curved and you'd have to fill the gap more or sand the port ring down and contour it yourself with a dremel or something.
Like you I couldnt really find them at a good price. West coast sailing I got some from once but their website naming is random and depending on if you search for port or hatch or whatever it brings up different products so I couldn't find them again.
I just bought a two pack "kit" of them from these folks as when I tried to purchase from Murrays they were out. Stock in the field is all that's left for now. Note, I even tried the original manufacturer, Viking, to no avail.
Another potential option would be to open up the hole to 5" diameter. 5" ports are much easier to get your arm into either when doing repairs or just grabbing stuff out of the hull while on the water. My old Hobie 17 had 4" ports and my arms would always get scraped up on the inside of the ring when reaching into the hull.
Murrays sent customers a notice that Viking was going out of business, and offered a sale early this summer. The people that made the nice contoured ports are no longer in business as far as I know. I have treated my ports with marine paint so they won't deteriorate.
Mine has 3 per hull. One in front and behind the dagger board and one behind the rear beam. When you have a nacra as old as mine I'm pretty sure you had to have them to build the boat. It's a stringer hull so it's in 2 halves. You'd need access to finish the dagger board trunks once it was together I figure. Totally possible they were added later but all the once I've seen online have the same ports as mine. The rear one is obviously for the rudder bolts since nacra doesn't do the glassed in plate to tap into like the hobies.
Even the first one built only had the 2 behind the rear beam. The other indicate there were issues with the boat. Most likely were dagger board well leaks and bolt failures related to the SS straps holing the beams.
Old trick to shape the hatches to the deck, JB weld, or any other epoxy putty, just apply around flange, press into deck hole, scrape off excess, wait to harden, drill fastener holes and go sailing. I did this on my Tornado and worked just fine.
Received the contoured ports today . They are made for the Hobie 16 ( Hobie Part # V1130) but fit my Nacra 5.2 perfectly. Thanks for all the input fellow sailors
1978 Nacra 5.2
