Last day of the sailing year had a nice couple mile race between the Waves. The stock boat got destroyed by the boat with a solid aluminum mast. It wasn't even close. This must be fixed or next season is going to suck.
Has anyone put a stiffener inside the tip to reduce flex. We use some small carbon fiber composite tubes at work and it got me to thinking. If I can get a 1.5 or 1.75 inch carbon tube inside the comp tip and down into the main mast, it could really fix this spaghetti situation. Has anyone tried this? The foam looks like it could be an issie.
I may need to pull the rivits and see how much room I have. I do calculations like this all day for work, so I can figure how much a given size tube will flex. It will be limited by the tip interior features.
Tubes are only a couple hundred dollars in regular stiffness material. It wouldnt be class legal, but this is just racing with my buddies.
Maybe this could go in a new section titled "things sailors think of when the lake ices over"?
