I use these in a couple of places:
1. On my side stays to pin the shroud to the adjuster plates. Once attached, both are covered by either a tight-fitting molded cover or a length of PVC pipe to protect from lines and people catching the rings.
2. On the gooseneck pin that holds the boom to the mast and hangs free, but all nearby lines are kept clear by bungee cords in a web.
Everything else is a forged shackle excepting the oversize quick pin I use for the mainsail clew, allowing quick de-powering when arriving on the beach or dock.
