Posted: Jun 05, 2008 - 03:56 PM
What make is the boat, all have some type of problems along the way. Is the batten tension to tight? do you have one of those god awful sail guides that some H-16s have in the sail track with the sharp edges, if it a P-16 P-18 check the mast head sheave and see if they need replacing, is the bolt rope in the luff of the main still attached at the tack of the sail if it comes loose it will creep upwards and become larger and that will make the sail more difficult to raise. Is it a larger cat with an internal halyard that pulls from the base of the mast and if so it could be another set of problems. Every thing I have mentioned is very easy to remedy. Just post the type of boat you have when you have a question and you would probably get more and faster replies.
