Posted: Jan 15, 2018 - 11:20 AM
I have them on the 5.7, ('84), though our 5.0, ('88) does not use them.
The idea is to change the sheeting angle slightly, slide the jib block further back the higher the wind gets. I think the idea is to regulate leech tension, and/or choke off the slot. If I were a competitive racer I might pay more attention to them, but in practice I mostly leave them. On light wind days I might slide them forward. If the wind is really honking, I will pull them back, or just leave the jib furled, though tacking often becomes a 3 point turn.
Just looking through my album here, I don't have a photo showing the location. My boats are boomless/boardless, not sure if the position of the tracks would be the same.
If you look through the old Nacra assembly manuals, you will see that the tracks appear to be in different places on different boats. One photo shows the front of the track about equal to the pad eye that holds the skippers trap bungee, ( behind the edge of the daggerboard). Another photo shows the track end about equal to the centre of the daggerboard.
One thing to be aware of if you add them, you also need the little sliding "cars" that go into the tracks, & it is beneficial to use the Harken stand up springs,(between the slider & the attachment post of the jib block). They keep the block from banging around on the hull/tramp & wearing it.
Also, although they look identical, the sliders from my H18 Magnum & N5.7 are not interchangeable. I didn't like the Seaway blocks on the H18, & tried to install the Harken blocks from the Nacra. I could not just attach the Harkens to the Hobie slider, as Hobie block is permanently attached to the slider. The Harken slider is just slightly thicker, & would not go into the Hobie track.
The slider track rivets to the aluminum track that holds the tramp. For attachment you need rivets with countersunk heads, & need to be careful if you have to drill new holes in the track. The heads must be flush, else you either won't have clearance to get the car in the track, or it will hit every rivet when you try to adjust it's position.
It depends what you mean by "better". I personally do not like the wire system on the original 5.2, it clutters up the tramp & is great for removing skin, but it might be incrementally better performance from the jib.
Edited by Edchris177 on Jan 15, 2018 - 11:46 AM.
