I have already primed one hull using preckote. I used a foam roller.looks ok. Tomorrow I will try the roll and tip using brightside.I will hang it in the air but it will be tricky going all the way around the hull and tipping because of the drying time. I figured I would roll about 14 inch wide area all the way around and then tip it,then roll again and repeat.I will roll vertical and tip horizontal. I thought I might spray the barn area where I am working good with insecticides. The bugs are thick. After the pre kote primer I will sand using 320 grit,then wipe using the 333 thinner then use a tact cloth. I am hoping to use just one coat of the brightside paint. It's so expensive and just bought 2 quarts. Any thoughts? Thanks
Tom Bainbridge, Ga. Hobie16, prindle 18.2
