Not a polyester paint like brightside or 2 part perfection paint by interlux.I bought this paint from our local paint Store and it was a 2 part paint with the epoxy in one can and hardener in the other. I spent hours and hours on the brightside with 4 coats and it did not work out. That paint goes on so thin and light sanding it was not a good paint. I spent over 400.00 and countless hours. I ended up sanding the brightside down and went with the epoxy. Put 5 coats on and wet sanded with 500 grit then 800 grit then 1200 grit. Then compound and a wax. Looks like a new car. It takes only 2 quarts and 2 quarts of harder. Also use 25 percent thinner a special brand and I can get the name later. This paint mixed is very thick. The cost is about 100.00 The brand of paint is Richard's. The owner said he did his boat 8 years ago using this paint and still looks great.I sprayed this paint must use 25 percent solventhinner. Roll and tip looked like crap on the brightside. Just spray.
Edited by ec on Mar 29, 2018 - 10:49 PM.
Tom Bainbridge, Ga. Hobie16, prindle 18.2
