I was cleaning up the Hobie today, getting her ready for the season, and I noticed a couple of small chips in the gelcoat and I'd like to touch them up. What would you guys recommend for small repairs like that. It just the gelcoat, not down into the fiberglass. Thanks for any info.
-- Marty
Opelika, Al / Lake Martin --
Mix up in a cup, add some thickener (milled glass fiber) to make a paste, brush onto chipped area. Cover with packing tape to help smooth out the surface. After cured, sand smooth as needed, polish and wax.
Thanks. So I guess I could get one of those kits and try to color match the gelcoat, I seem to remember seeing something from West Marine or something like that.
-- Marty
It is my understanding milled fiber is not a thickening agent. It is a tensile strength additive and not the best choice as a thickener (at least i was told this by a professional repair person)
I would use a silica product as a thickener (or other), and add some mill fiber for strength, but not as the main product for viscosity control
Page 26 of this west system document shows lots of data about using additives to epoxy, and it's pretty much the same with gel-coat (as far as i know) https://www.westsystem.co…ads/User-Manual-2015.pdf
it's good to know the different levels and ideal consistency needed before you start mixing
I agree, there are numerous products that can be used for thickening. I didn’t intend to imply that milled fiber was the only option although I do think it’s a good choice since it will add strength to the gelcoat. But you’re right, cabosil would also be a good option and there are some others that would work as well. Depending on where the chip is located, you may not even need to thicken at all.
I have one chip at a bow tang, it's been there since I got the boat 2 years ago and hasn't changed in size or anything, it is very small but I figured I would touch it up. The other chip is at a side shroud anchor and it too has been there since I got the boat with no change in 2 years. Again, these are really kind of small chips and they are only gelcoat and not chips in the fiberglass. I saw a repair kit that uses talc as a thickening agent.
-- Marty
I too use silica as the thickening agent.
I also use a different material than the tape. I put a couple of layers of tape near the repair and then I tape down a piece of the slippery backing off of roofing ice dam material (over the repair). It is fairly thick and leaves a nice gloss and it only takes a little bit of material anyway. The layers of tape near it give you a bit of height to the repair that you can then sand down, once all cover and tape are removed.
There are numerous ways and methods on these type repairs, and everyone seems to have their own tricks of the trade.
-- Supercat 15
Windrider 17
Shallow water sailor in the Delaware Bay --
For small chips and true deep scratches this is what I use. It goes on pretty thick, but you may still have to use the tape idea or something along those lines to hold enough material in place till it cures. This is the type of gel-kote called "waxed" so it will cure without an oxygen barrier. If you don't get enough void fill in one application sand the surface and apply another coat (rinse and repeat as needed).
I didn't even know they made fiberglass tubs - how fast are they? (jk)
One thing not mentioned until Leeboweffct's post: you need to use a wax additive or similar (sanding aid) so the gelcoat cures and isn't "tacky" - (soft and will clog up sandpaper)
Gelcoat repair kit: Unfortunately not, the evercoat ones I've tried SUCK, they are 1 part systems and don't cure properly. Also not very useful on colored boats.
What you need: color matched gelcoat, fresh MEK, mixing cups, foam brush or Preval sprayer, green or purple PVA in a spray bottle and painters tape. This is the PVA I am talking about: http://www.rexco-usa.com/wp-content/uploads/2011/06/cov-1.jpg
The tips on tape and cabosil are good ones, but I find the need for thickening agent isn't really there. Sand an area 2-3 times larger than the chip to be repaired, so you can feather the repair. Tape around this. Let the gelcoat harden up some (cure time is controlled with the amount of MEK you use and the temperature of the work/ambient conditions), then take the foam brush and apply to the area. Let that get pretty tacky, I wait at least 30 minutes, usually an hour. Then spray the gelcoat with PVA, or you can brush it on with a separate foam brush. PVA forms an air-tight barrier without the hassle of wax additives that clog up sandpaper.
Finishing: let the gelcoat cure a minimum of 6 hours, overnight is better. Come back in with a sanding block and 320 grit sandpaper, if you have a lot of buildup maybe 220 grit but you have to sand the low grit marks out as well so I prefer to start with 320 and work my way up (to 1500 or 2000 grit than polish). I use credit cards for small areas and this block for larger areas: https://www.amazon.com/gp/product/B003WUYG1E/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
I've personally never found the wax additive to be a problem. You just add a few drops of it when you add the catalyst. I've never noticed any issues with it clogging up the sandpaper. Clogging issues happen when you try to sand gelcoat/resin that isn't fully cured.
I think the effort/expense of spraying PVA over what sounds like some very small chips in a 30+ year old boat seems a little extreme.
Nope, shoot it straight. I don't even spray it-I use a spray bottle from meguires: https://www.autogeek.net/meguiars-spray-bottles.html
Dogboy, you may be right, but I maintain my boats so they look like new. Spraying PVA over gelcoat is easy and not expensive, but then again I also buy it by the gallon for use in composites fabrication.
Good thread.
I need to repair a spot where a small padeye pulled out of the hull (#6 screws) and I want to fill the hole, then redrill. What can I mix with the resin (ground fiber?) before I fill the holes? I envisioned using a cheap syringe like those used for irrigating wounds to push the resin into the holes. Then gelcoat, redrill, and reattach padeye.
Edited by ropewalker on Apr 10, 2018 - 07:28 PM.
-- Brett
2012 Goodall C2 with 2014 Hulls (warranty)
1992 Hobie 18 w/ SX Wings (Sold)
Tucson, AZ --
Yes, great info as usual guys, thank you for all of the input.
For what its worth,the chips on my boat are less than the size of a dime and although the boat may be 30+ years old, she looks good for her age and I want to keep her that way.
Edited by martyr on Apr 10, 2018 - 08:41 PM.
-- Marty
This stuff works great for cosmetic dings on white hulls/rudders: https://www.fgci.com/item…PINT-uses-MEKP-catalyst/
Wax is included.....just add catalyst. I'm pretty sure they produce it....never had issues with shelf life which can happen when buying at a box/hardware store.
Color matching a 30 year old yellow hull will be the problem. It's likely a different hue on different areas of the boat. The materials are quite expensive to be wasting on trial and error.
FGCI either produces it or resells it under their name - I use their stuff all the time (they are local to me)
Not saying this product isn't fine but ...
This product is actually more expensive (per volume) than regular gelcoat from this same company, which you can purchase with or without wax too - (and just add MEKP)
Tint in very cheap too - under $5 a jar but not sure how/if it will mix with this putty
and you may need a second color to darken or lighten it to match - you can play with minute samples of gelcoat and tint (and mekp) to color match
I would use thickened epoxy (thickened with some silica or cavisil), then add a little mil fiber for strength
I wouldn't worry about a syringe (mil fibers may clog it ), and just use wax paper to push it into the hole
I would probably re attach in a slightly different spot too since there is a fair chance there was some water intrusion in the open holes - degrading any foamcore
"Color matching a 30 year old yellow hull will be the problem."
Understandable for sure. Fortunately this boat was garage kept and covered up when outside. I keep it covered constantly.
i would bet color can fade/ change a little with time, even in optimal storage - so even if you purchased Hobie yellow gelcoat, from hobie ... it may not match 100%
If you don't want to match it yourself with tint -
I would personally go to the hobie forums and ask others with yellow hobies what they use (or
small color differences will not make you any slower - so who cares :)
At work we wet sand defects out of freshly primered kia bodies by hand with a 3 inch diameter squishy foam palm sander that has a sponge in the center of it and is called a "nubby". We use 800 grit in the primer booth that I work in and the nubby is fairly flexible. I think it would work well for gelcoat repairs.
-- Marty
Okay I found out that the palm sander is made by 3M. Being not very "tekie", I still cannot seem to post pics within the forum so I created an album in the Beachcats Technical album labeled "3M 3 inch diameter palm sander" . If anyone wants to post the pics in this thread, then by all means, feel free to do so. Sorry the pics are sideways also but I think you can see that the palm sander is a bell shape and fits your hand very well. I hold on to one of these things for 8 hours a day so i know these things well. Hope this helps somewhat but I have no idea how to order the things.
Edited by martyr on Apr 27, 2018 - 09:28 PM.
-- Marty
I googled "3M hand sanding" and found the palm sander. It's called "Hookit". I added a screen shot picture to the sub album in the Beachcats Technical album.
Edited by martyr on Apr 28, 2018 - 05:01 AM.
-- Marty
Yep, that's the one. I didnt think to show the hole in the pics of the one I have, but it does have the hole in the top as well. Thanks for adding the pics MN3.
Edited by martyr on Apr 28, 2018 - 10:11 AM.
-- Marty
I just went to a gel coat seminar by a large working marina (Torrensen Marina) that serves mainly sailboats. They perform all types of fiberglass work, paint and repairs on boats up to and over 70'. They have rebuilt & repaired production yachts as well as hi-tech racing boats. The service manager said that if he could get a guy that could get the gel coat color right on the first try he would hire him immediately. They do have a system that is hard to explain, but he said most mistakes are made by not cleaning and getting the immediate area clean and brought up to a nice shine but no wax. Because when you go to sand the new into the old you will get to that shine and the color match will be off.
He also said that you should mix up 3 x more than you need for the color match, (no hardener). Keep the extra in a refrigerator. One guy gets it as close as he can and then at least two others look at it from no closer than than 3' away. Natural light only, no fluorescence lighting. Adjust color until all three say its OK. If you have a quarter size ding, he tapers up to 8" and uses plenty of Duratec for thinner, never acetone. Spray & sand. His final coats are more thinner than gel coat so they can blend the gel coat in.
If you want a perfect patch you will need to spray the whole boat as there is no such thing as "perfect", only very close.
Wow, you got decades worth of expertise in that seminar.
Jealous.
Where is this marina?
-- Sheet In!
Arizona, USA --
I replaced both bow tangs last year and spent lots of time trying to get the exact amount of pigment to match my boat. working in small and numerous batches it was a giant PITA to repeat the exact amount of gel/mekp/pigment/and wax since i am in a garage, not a controlled lab/shop (and not an expert by any means)
it never really matched all that well but since it was only the top... and not "lined up" with the freeboard) it's really not noticeable unless someone with a good eye examines it. and i don't care enough to care about their opinion
i am currently doing a bottom job on my spare catamaran and have added a fair amount of non tinted gel coat
while fairing: i have sanded through a couple spots on the tape line: only to find the white gelcoat I am using is an almost exact match for my boats original gelcoat (1994 model, never re-gelcoated as far as i know)
So it ends up: all that tinting i did was color-matching to old dirty gelcoat
i gonna leave the brilliant white new gelcoat and the old dirty gel coat the way it is - and call them racing stripes
Yep, that's the one. I didnt think to show the hole in the pics of the one I have, but it does have the hole in the top as well. Thanks for adding the pics MN3.Edited by martyr on Apr 28, 2018 - 10:11 AM.
i think it's brilliant to be able to run water through it
We simply dip the sanding end in a water tray and the center sponge soaks up water and also holds any sanding residue. We use this sander on freshly primered bodies of multiple colors. The water trays are like small sinks mounted on the wall of the booth at each station and have two chambers, water is in one and a flat brush is in the bottom of the other for cleaning the residue from your sandpaper. The process is dip, scrub the sander across the brush, squeeze out the excess water, sand in a circular motion keeping the palm sander flat.
-- Marty
-- Sheet In!
Arizona, USA --
