Posted: Apr 17, 2018 - 05:09 PM
I read a post from Matt on Hobie.com that the Wave is cross-linked polyethylene, and that it can't be welded... if you heat it enough to fuse it, it doesn't get gooey... it liquefies and runs. Messy. The upside of cross-linked PE is better impact resistance and surface shine.
I have had a kayak made from linear PE successfully welded, and it works well. I've also patched a Royalex boat (composite material: layers of vinyl, hard ABS, and foam) with epoxy... G-flex epoxy was unavailable at that time. That's what I'd use today, and what I recommend for cross-linked PE -- it sticks to plastic and has some flex. I've read that 'preheating' cross-linked PE makes it easier to stick to (beyond just mechanical roughing up, there's something chemical at work). Google kayak repairs for TONS of info on this... that hobby has been doing this for longer and more often than the Hobie community.
Randii
