California-winter sailing in February (is it really winter when there's no 'hard water' to be seen?) netted me a broken link on my Ronstan 55 series jib blocks: https://www.ronstan.com/marine/orbitblock-instructions.asp
On closer spring-cleaning inspection, the opposite side was getting a bit ratty, as well, so last Saturday night, I pulled out some scrap 3mm SK-90 Dyneema and the splicing tools. More hours later than I care to think about, I threw in the towel and did two small loops with a square knot in each, with the tails whipped, lock-stitched, and then over-whipped. That got me out on the water Sunday... but "Knots, splices, stitching, etc. will generally have a lower Breaking Load than the rope itself."
I have had good success eye-splicing and also making soft shackles of this small line before, but I just could not get it to work on 3mm line in such a small loop. Larger hollow-braid expands more relative to its diameter, any tips on working with smaller splices... my commercial fids are too big for tight loops, and my home-built ones aren't much smaller!
I will probably just throw my purse at the issue and have APS send me a pair of $10 Ronstan replacements (I'll set the square-knots aside as emergency spares), but I'd really like to be able to buid these on my own. Any tips or suggestions?
Randii
